industrial wet vacuum manufacturer
I am working on a project, and need a wet vacuum system - vacuum water off the surface of the vehicle after the washing process inside a washing booth. Does anyone know any manufactures dealing with this kind of vacuum? In order to separate the water, does the traditional cyclone separator work? Thanks in advance!
RE: industrial wet vacuum manufacturer
You could use a liquid ring vacuum pump.
Just google "liquid Ring Vacuum Pump" look for system builders.
Good Luck
pennpoint
Have your wife call a carpet cleaning service to come out and clean your carpets.  Stay home that day and chat with the operator, ask him to let you look over the machine.
You'd be surprised what you can put through a cast iron "Roots" blower without damaging it; if the rotors get wet, just squirt a little spray lube through it at the end of the day.
