Edition Differences in the Mechanical Engineering Reference Manual
Does anyone know if there's a big difference between the 10th and 11th editions of the Mechanical Engineering Reference Manual by M R Lindeburg?
Is the companion book of practice problems worth while?
Thanks.
Thanks.
RE: Edition Differences in the Mechanical Engineering Reference Manual
You will need the practice problems book because it has the solutions to the practice problems found in the MERM. Only the answer to the problem is given in MERM, no solutions are given except for the occasional example problem.
You will want to order the NCEES sample exam and work that just like a real exam, about 3 weeks before the actual exam. Lock yourself in a room for two 4 hour sessions and work the problems with your references. Take notes while you are practicing of things you want to make sure you have during the exam and references you need but might not have. Good luck!
If you follow the advice that Jpankask gave you, you should be fine.
David Simpson, PE
MuleShoe Engineering
www.muleshoe-eng.com
The harder I work, the luckier I seem
i have already de high corossion rate on second desalter on separation system.
i take reading on line water outlet dessalter.
condition on T and P are still constant but the reading are already in increasing only in second stage.
injection is working with demulsify and scale inhibitor .
in the plant we have six trains but the problems its appears only in two trains.
why? which approach do you take for explain this situation?
advice me and best regards for everybody.thanks a lot
You should ask this question as a new thread, people who can help with a desalter issue may not ever read a MERM-reference thread. (I'm not going to red flag your message, but you probably should)
David
If Fatiha42 Red Flags his post, will that just result in the post being deleted, or does the whole thread get taken down with it (which would probably be a shame)?
A.
