Heat Equation
Heat Equation
Heat Equation
What is the preferred name for the following equation:
Q = m*Cp*deltaT ?
For instance, P*V = n*R*T is called the ideal gas law.
Thanks.
RE: Heat Equation
I have not heard this equation called by a particular name other than, "required heat" or "specific heat".  However, for those not familiar with the equation.  It is; the amount of heat to be supplied to or extracted from a substance to change it's temperature.  This equation is commonly used for liquids and solids.  Where the specific heat is generally independent of pressure.
Where:
Q = heat
q= heat per unit mass
m = mass of substance
Cp = specific heat of substance
delta t = temperature difference
Therefore:
q = Q/m
Cp = Q/m(delta t) = q/delta t
Q = mCp(delta t)
http://www.johnzink.com
Industry's hottest new site for all things combustion.
RE: Heat Equation
This  equation is essentially a statement of the first law of thermodynamics in terms of Avg. Cp (rather than enthalpies). Heat input (Q) = (Heat absorbed).
-j.katz
