surfaces in wildfire
i have been using proe2001, when i create a surface i can use the "flat" option and draw what i want to be the surface. In proeWildfire, i am unable to find the same option and can only extrude a surface from what i have drawn. Since i no longer have access to proe2001, i need to know how it is done in wildfire.
Any suggestions?
RE: surfaces in wildfire
Go to Edit Fill
Try the Menu mapper on the Ptc Website
Brian
Late answer, but use "fill" in the edit dropdown menu.
