ACAD 2005 - SELECT OBJECTS IN DIFFERENT LAYOUTS
I have 11 title blocks in 11 different layouts in one drawing. I need to fill out a new line in the blocks - the same on each.
Is it possible to slect all the title blocks in the document and edit attributes to them all at one go?
RE: ACAD 2005 - SELECT OBJECTS IN DIFFERENT LAYOUTS
If you know LISP, you can do a
(ssget "x" '((2 . "YOUR_BLK_NAME")))
to get a selection set of your titles and then just iterate through them.
"Everybody is ignorant, only on different subjects." — Will Rogers
There is a command that I believe is part of the express tools, that is "Global Attribute Edit"  the command is "GATTE"
This should do what you want.
