Belt Tracking Question
Hi guys,
I have a question that I am trying to find an answer to. I have been browsing the web looking for an answer and have found your site, hopefully you can help me out.
I am a field service tech looking for a comprehensive answer to provide to my enginneering team regarding belt tracking. I have found in the field that a belt (conveyor belt, or timing belts) tends to track towards the "tighter" side of the adjustment pully. Or, if I have a ballanced pulley/belt system, say a conveyor, and I tighten the right side, the belt tends to travel to the right, towards the tightened pulley.
This isn't making sense to me. By tightening the pully/belt on one side only (adjusting the adjuster bolt to increase the overall diameter of the one side of the belt) I would think that I am "tapering in" the other side, and the belt, being under tension would want to slid down away from that side, essentially reducing the tension on the belt....I'm confused, why is it climbing the pulley and becoming tigher????
You help is greatly appreciated in helping me cure this headache!!
Any links with discriptive answers are greatly appreciated,
Thanks in advance for your help, John
RE: Belt Tracking Question
