Keyseat automatic dimensions
Hey guys
This kind of a hard question to ask but ill try to explain it as cleary as possible.
You know the hole callout button in drafting? well that fonction automatically detect the diameter of a hole the user just types in the quantity.
Well my supervisor asked me if its possible to have the same idea applied to keyseats.
For example just by using the hole callout on a keyseat it would automatically give a dimension with the width and the depth in 1 step.
Would it be possible to do it with hole callout?
Hows does hole callout detect diametres anyhow?
Do you guys thinks it would require a seperate button with some VB programming?
