Bolt Hole on CJP weld line
I need some sources or references to sustent my position in order to reject a steel member which has a shop welded splice with a bolt hole located on the line of welding. The joint is a CJP and is joining WF shapes.
Thank you in advance for your help.
Regards.
Nymous.
Regards.
Nymous.
RE: Bolt Hole on CJP weld line
In general, however, to decide on such a matter, a stress analysis should be performed that takes into account the direction and amount of stresses in relation to the weld.
Furthermore it would be important to establish if the steel member is subjected to fatigue stressing.
http://www.welding-advisers.com/
Hg
Eng-Tips guidelines: FAQ731-376
Just a quick question here- I am wondering why you are looking for substantiation to reject something instead of tools for evaluation to see if it will really cause a problem or not?
Hg
knowing the application and how the
hole is used or even the forces that
are acting on the weld. The problem
is too vague. What forces are acting
on the weld design?
Hg
