Save as PDF drwing sheet control.
Hi all,
Is there a way using "Save as PDF" to control which of the drawing sheets are converted. We use a second sheet on a drawing for our sheet metal flat patterns. When we create the PDF we do not want this sheet of the drawing included in the PDF.
Thanks for the help.
RE: Save as PDF drwing sheet control.
Making the best use of this Forum. FAQ559-716
How to get answers to your SW questions. FAQ559-1091
Helpful SW websites every user should be aware of. FAQ559-520
Why not print instead of saveas PDF this will bring up the print dialog which has a print range so you can choose the pages.
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
Not quite sure what you mean.
How do you print and create a PDF?
http://www.pdf995.com/download.html
John
If you have Adobe Acrobat (not just the free reader version, but the full blown purchased version), you can create pdf's the traditional way. That is to print them to Adobe.
The other option is to delete your flat pattern page before you save as pdf. Then close the drawing without saving because you don't want to permanently delete the flat pattern sheet.
Best Regards,
Heckler
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
o
_`\(,_
(_)/ (_)
Fill what's empty. Empty what's full. And scratch where it itches.
Would you care to share that macro?
Chris
I found a macro on the web that should do what you are asking about. The macro download is called "SaveAsPDF
WhatToPlot.zip" and can be found at this website: http://www.cadimensions.com/macros.htm
Best Regards,
Jon
Challenges are what makes life interesting; overcoming them is what makes life meaningful.
Solidworks 2005 SP2.0
That is a great macro. I downloaded it and works slick.
Thanks for the info
I glad you enjoy it.
Best Regards,
Jon
Solidworks 2005 SP3.0
This macro works great.
