add-in problem starting Solidworks with createobject
When starting a solidworks session in VB by means of createobject and opendoc6 functions, no self created add-ins are loaded.
You can load them by dragging or using the loadaddin function.
This works fine. The problem is that you get a memory error (read) when closing the swx session when the add-in is flagged in the add-in manager.
Problem also exists fe with the 3D content central add-in.
