Information concerning ANNEX 1 (Motor Grounding)
Can someone please lend some of their knowledge concerning Electrical Motor and Industrial Structional Grounding. The RFQ is for the I&E Installation for the power and control of a Gas Regeneration System will be installed and operated in South America. I just recieved a RFQ that states that I must ground electrical motors in accordance with ANNEX 1. The motors that will be used to operate Process Gas Compressors, Produced H2O Pumps and Lube Oil Pumps will be rated 480VAC 3 Phase with 220VAC Space Heaters and Thermistors. Also, in the same RFQ it states that I must ground the Gas Regeneration System's Skid assembly in accordance with ANNEX 2. Can someone enlighten me on these subjects. Thanks for your input.
RE: Information concerning ANNEX 1 (Motor Grounding)
