Advice for engineer in a technician Job
Hello all and thanks in advance,
I am currently an field service technician at chiller manufacturer. I am finnishing my masters degree.I am working with engineers, and I am being given tasks in both field and engineering. I enjoy my work, and its got a great learning curve. I am concerned about the experience in respect PE qualifications, and getting "stuck" as a technician. Any advice in regards to steering my career in the right direction? Has anyone been in a similar position?
Thanks again
Thanks again
RE: Advice for engineer in a technician Job
My engineering BS and MS are both in electrical, specializing in controls and power electronics. I have quite a bit of x-tra technician coursework in PLC programming.
I took a technician position, because I had 3years of professional inactivity, except for the MSEE and PLC courses. Does the title really matter for PE qualifications though? They were/are excited to bring me on board, but I feel that this company puts the cart before the course on a lot of things. So, I have reservations about the long term benefit of the position. As for right now, Im programming, making contacts, learning, etc.. So Im happy, but I have EE degrees and I want to use my background it.
Let's see now, you are programming PLCs, supporting chillers, etc. Where are you located and where do you want to be when doing control systems design engineering?
John
Actually this afternoon, I spoke with my supervisor and one of the senior PE's. They've agreed to give me the title Filed Service Engineer over Service Technician.
We actually have several PE's on staff, so Im okay in that department. I guess the only thing to do is "do" some engineering and get that qualifying experience.
I guess it pays to communicate.
Thanks much for all your inputs everybody
Since your title was changed, I can't imagine that your future experience with this company would not be allowed to apply to your PE requirements.
http://www.ncees.org/licensure/licensing_boards/
However, your graduate school time will most likely count as a limited amount of experience for the PE exam - again, check the state laws.
The subject of having your work directly supervised by a PE has been discussed recently (this is usually not the case). See this link
Thread731-119480
www.SlideRuleEra.net
Thanks for the comments and information. I will follow up with the research for sure. Im real luck I have a few PE's to work under. I took a "department exam" to meet the graduation requirement, which essentially was an EIT practice exam administered by my college's EE department. I plan to take the fall examenation.
Thanks again
JT
Not many people do, though they have fancy titles and designations !!!
HVAC68
Im pretty excited, there is a lot to learn, but I'm still comfortable. I get to see more factories than I can shake a stick at, and Im not confined to a desk. Plus they are real nice people.
The only issue I had for the title was the P.E. qualification issues.
Good point though HVAC68, enjoying what you're doing is such a necessity.
1. Good pay, but no job satisfaction,no enjoyment.
2. Bad pay, but lot of enjoyment and satisfaction.
3. The best one - good pay and you love the work.
Of course, the third one is the best to be in - however, there are also varying levels of satisfaction and pay in the first 2 categories - and generally, it's very hard to measure these things - it's so relative in nature.
Anyway, good luck - and enjoy your work.
HVAC68
On a quick note I would like to add one more type of job which I guess apparently you missed out.
So continuing on the list of types of job
4. Bad pay, and no job satisfaction, no enjoyment.
and this can very well happen due to various constraints. And when somebody wants to get out of the this type of job as the constraint is no longer such a big factor, they can not do so, however hard they try (atleast for the moment).
I hope others and you might agree with this.
Lonecrusader
HVAC68
