Admin image question
The admin image we create is 2.75 Gig. It contains directories like Archivos de programa, Programme and Programmi. I need to copy the image to another server but I would like to trim the dead weight of the 2.75 gig image. Can someone tell me what is safe to delete?
I created the image from an English SP download, not spanish
Thanks in advance
Thanks in advance
RE: Admin image question
If you edit the file and something goes wrong, it could affect everyone linked to it.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
Also if you do test it and there are no obvious problems, there could be once you try to apply the next SP. When that happens, I would bet that the SP will fail. Best case the SP would add everything you deleted back in and you would be back to where you are now.
Worst case would be if the test seems fine now, but many "grimlins" show up later which will be extremely difficult to track down.
Besides, 2.75 Gig is not bad. I just checked mine and it's 4.51 Gig.
