Pull Pit Applicatins
Hi there,
I am continuing a project which already designed by other engineer.
I have two questions:
1) The transformer size is 750 kVA. what is the advantages and disadvantages of owning transformer by client or Hydro?
I already knew that if Hydro owns it they will charge a maintenance fee on every kwh consumption.
2) In the design, engineer considered two electrical pull pits, one at termination pole where hydro supply line exists( which if hydro owns the transformer not needed, I believe) and another one at pad mounted transformer primary and the supply is duct bank buried.
Do my client really need these two pull pit?
What's the application of Pull pits? Isn't it like pull boxes and manhole for ease of cable laying?
Any reference, link or comment would be really appreciated.
RE: Pull Pit Applicatins
I am not sure what a pull pit is, but it seems something like a joint bay.
Eases cable pulling
Gives access to the cables in future.
Place where you can joint cables.
