trajpar problems in 2001
I am trying to use a variable section sweep to rotate a surface along a trajectory. My problem is that every time I try to do this, trajpar evaluates to zero and the surfaces doesn't rotate around the trajectory (it just stays parallel to it). I'm using a relation like D6=trajpar*360 where D6 is the angle of the surface. I don't understand why this won't work.
RE: trajpar problems in 2001
NrmToOriginTraj—Select the Origin Trajectory
Norm To Traj—Select the Origin Trajectory and an additional trajectory to which the section will remain normal.
Also check out:
Thread554-24639
Thread554-67609
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 2.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
Do you trust your intuition or go with the flow?
Hope that helps
Dave
Dave Hyman
iRobot Corp
www.irobot.com
