Screws in Light Gage Steel Framing
The nominal screw shear strengths for both AISI and NZ Code are very close to each other. But in AISI the resistance factor is 0.5, in NZ Code it is 0.9. The governing vertical load combination is same in both of these codes : 1.2DL+1.6LL. What is the reason for this difference? One of the codes should be either too conservative or unconservative isn't it?
NZ : New Zealand Code
RE: Screws in Light Gage Steel Framing
