Map File not Working in Task Scheduler
SWX 2005 SP 2
I am trying to batch convert alot of drw's to dwg's. I can open up a single drw in SWX and do a saveas to dwg and change the options to point to my map file. The file comes out fine. When I take that same file and set the task scheduler to convert that file, with the same map file set in the options, it converts it but the map file isn't used.
Has anyone else had this problem?
