intralink 3.1 check out problem
While checking out parts from workspace to commonspace
our power was shut of for a couple of minutes.
When starting up the parts that were checked out are now locked by myself, I have deleted the workspace,
the parts stay locked.
Johan
RE: intralink 3.1 check out problem
vanpeltnv
The files are locked in the commonspace, so you either go in the commonspace and unlock(change status) them from there or if you have the files in your workspace, select the files choose change status click on the commonspace tab and unlock them from there.
Jesmond
