Default Plot Server
Default Plot Server
Hi Guys,
We have just introduced NX2 from V18.
In version 18, when the Plot dialogue box opened, the plot server was always set to the correct one.
However, in NX2 I have to select Change Plot Server in order to point it to the correct server.
Is there anyway I can set the default plot server in NX2 in a similar manner to V18.
Cheers,
Andy.
Cheers,
Andy.
RE: Default Plot Server
! Default Plot Queue Name - This is the pqmgr (plotter) queue name that UG
! defaults to when the plot menu is pulled down. Enter the Primary plot queue
! here. Name MUST be all Upper Case: (i.e.: TEST1)
! (16 character maximum)
UG_defaultPlotQueueName:
! Default Plot Server Name - This is the hostname of the default plot queue
! server (default node to plot to). UGII_PLOT_NODE= overrides this .def file.
! (32 character maximum)
UG_defaultPlotServerName:
-Dave
Everything should be designed as simple as possible, but not simpler.
