Component module is missing
Hello all
I am designing a machine so all of machine components put in working directory.
In order to manage machine modules,i put some components in sub-directory under working dir.
Why does pro/e ask me to find the components under sub-directory when i restart?
thanks
thanks
RE: Component module is missing
Pro/e wildfire 2.0
In Utilities, set the Option SEARCH_PATH to the different folders that contain your assembly components.
Save your modified config.pro settings, and make sure to activate them when you start ProE.
Steve
http://www.sprdesign.com
http://www.3dlogix.com
Could you give me the example for this ?
thanks
search_path sub_folder_name
You can also put search paths in your load_point\text\config.pro but then they will need the full path name. If you need a lot of search paths you can create a special search path file and point Pro to that. I like to keep down the number of search paths because it can take awhile if Pro has to look through a lot of folders.
