Extending the range of wireless networked pc
I have a Belkin FSD7010 802.11g wireless notebook network card and I want to extend the range. Unfortunately there is no external antenna socket on it to allow me to connect up a yagi antenna or a cantenna to boost the signal. However it seems to me that I ought to be able to reactively couple into the notebook card if I knew what I was doing and if I knew what sort of antenna was inside the card!
A half wave dipole at these frequencies (2.43GHz) should be 6.15cm long which doesn’t fit with the card size, although the metal cover is 8cm x 5.5cm. The unscreened section is only 3cm x 5.5cm.
At the moment the software is just saying no signal at all so it is difficult to tune the response using an external structure. All experiments to date have been null and I don’t have a convenient nearby wireless source.
Does anyone know what sort of antenna is used in these cards and if anybody has done any work on increasing the antenna gain using an external structure? (This is a just-for-fun home project.)
As a secondary question, on a yagi (as used on TV antennas) the directors are all earthed at their centre points to a conducting rod. Is the conducting rod part of the electrical design or just a support structure?
RE: Extending the range of wireless networked pc
It would indeed be possible to couple to your WLAN card with an external dipole, but I think I would try a full wave loop. At 2.43 GHz, you would need a loop 39.29mm in diameter. This also could easily be etched on a piece of single sided Printed Circuit Board. it could be cable tied, velcro'd glued or taped to your Belkin 802.11 card. To find the best place, try using a spectrum analyzer hooked to the output of the loop.
Good luck and please post how your experiment works out.
I remain,
The Old Soldering Gunslinger
The idea of measuring the Belkin’s output in order to establish the optimum coupling is obvious from reciprocity but apparently not obvious when looking at the problem from my kitchen! I might try that if I get a few minutes spare at work.
Can you tell if you just need to transmit more signal, or is your received signal also too weak.
If you only need to transmit more energy, then making an antenna/amplifier/antenna setup would boost your transmit power (possibly illegally) and you could transmit further. Coupling to your present antenna at -20 dB is reasonable, then add 30-40 dB gain amplifier and another antenna separated from the notebook antenna (to prevent oscillation). Look for mini-circuits amps, they're cheap and battery operated.
I think the antenna is a diversity pcb antenna, meaning there are two polarisations and the system picks the one with the biggest signal.
I think a passive system ought to work, but I am having no success to date. A corner reflector should give a reasonable gain so I made one out of aluminium foil , stiffened by cardboard from a cereal box. Good experimenters tools! I put this around the lump sticking out of the side of the laptop case (the plug in card has a noticeable lump on the end). Unfortunately the Belkin software doesn’t update the signal strength in real time so tuning for optimum signal strength is all but impossible. There is a nearby network to receive but the signal is so weak I can only receive it when in my loft! Not an ideal tuning environment. The Net Stumbler software also fails to update the signal value correctly which is also a pity.
I am not sure if the Soldering Gunslinger’s reciprocal antenna tuning idea is workable because it is not clear if the antenna on the laptop is transmitting when searching for a network. Certainly the power level being emitted is low (on average) as seen on my TriField meter, or rather as nothing is seen on it. Probably the transmit burst, if any, is a very short burst at best, and therefore not detectable on a long integration time power detector.
I believe that there is a rule that each time you increase antenna gain 6 dB, it requires 3 dB reduction in transmit power, that way you can have extended range with narrow field of view from your antennas. I'm certain there would be an upper limit for Effective Radiated Power (ERP) = Power x Antenna Gain also.
Check FCC guidlines for the details.
kch
