Does anyone know how to fix this....
I don't understand that "must be an scalar", the number is already an scalar!
RE: Does anyone know how to fix this....
your second variable "rho" is a matrix with the dimension 1x1 and no skalar (because it stands in brackets).
The easiest way to fix this, is to define a new variable like this: p = r[0,0
That extractes the 0,0-element from this matrix and writes it to a scalar variable.
That would work but I think, your mistake is in the calculation before, rho shouldn't be a 1x1-matrix. This occurs if you multiple a 3x1 with a 1x3 matrix as vectorproduct. Instead of this you can use the scalarproduct (3x1)^T * (1x3). But there may be other possibilities.
Sorry for bad spelling, I've only spare time.
Christian
I also tried to fix it with the solution that you gave me, but i don't understand it, is:
p = r[0,0
Now, i tried to write that but nothing happend, gave me an error, can you take a picture of that, like an example or something?
Thanks!
Your problem starts with the definition of d, since its result shows up with a parenthesis around a single number, indicating a 1-D vector.
The simplest solution is to select the end of the definition of d and tack on [0.  Since the vector is 1-D, [0,0 results in an error.
TTFN
The problem is that the vlookup function returns a vector.
From Mathcad Help:
Quote:
vlookup(z, A, c) Looks in the first column of a matrix, A, for a given value, z, and returns the value(s) in the same row(s) in the column specified, c. When multiple values are returned, they appear in a vector.
Apparently when a single value is returned, it appears in a one row vector.
IRstuff's solution should work.
HEY!!, that's perfect!!!, worked  BEAUTIFUL!!!
Thanks very much!!!
here it is........
