Cannot open Excel workbook
An excel workbook I had been working on "crashed" and no longer opens. There is some sort of "apologetic" message that apears, asking if I wish to send a report to MS. Is there some way of repairing it? I had been saving it every few minutes while working on it, but did not think of saving it as different file name each time.
RE: Cannot open Excel workbook
not that i'm aware of . . .
i've no idea what ms will do for you either . . .
sorry and good luck.
-pmover
ctopher,
The only "backup" consisted of an older version saved under a different file name, about a week ago (I lost about a week's worth of revisions to it).
I read in another thread that it would have been wise to have the "save backup copy" option turned on. Merely saving as a different file name is just as good.
Some possibilities that may have caused this: I was in the process of copy/pasting a worksheet from an Excel 2003 file to an Excel 1997 file. The "ASAP Utilities" add-in was running.
For some odd reason, this morning, none of my Excel files would open properly. I then tried uninstalling ASAP Utilities, and problem was gone (what the heck happened)
Have you tried opening the file on another computer?  Sometimes the XLStart file corrupts and you need to delete it and excel will write a new file when you first open it.
Try opening your corrupted file on another machine and see if it works.
PE,
It did open on another computer, but is worthless now. Only a few numbers showing, no text nor formatting, no formulae intact at all. There was a Excel message saying that the "damage" was too extensive. Sounds like a basic fault with Excel.
