Contact Manager
Contact Manager
Contact Manager
I am using contact manager to generate contact surfaces for sliding motion between two continuously contacting surfaces. The target surface is to be rigid, however, when I start contact manager, the "rigid" option is greyed out. I can only choose between "flexible" and "pilot node". Any idea why this is so?
icefea
RE: Contact Manager
I believe, that there has to be an unmeshed area, that can be pointed as a rigid target.
Thus yout target has be unmeshed in order to be rigid.
RE: Contact Manager
Hi Kottier,
Thanks for your rely. I'll try this and let you know if it works for me.
icefea
