Dimension size with a scaled drawing
When I am in drafting and have generated a "D" sheet at 4x scale, I find that my dimensions and lettering are very small since they did not "scale" up to the drawing scale. I do not want to go in and change text height, arrow size etc. for each drawing. Is there a dimension and lettering scaling default to do this. In my mind the dim. And lettering should stay the same size on the paper irregardless of scale. Is there a customer default in utilities to set this?
Vince Smith
Vince Smith
RE: Dimension size with a scaled drawing
"Fixed in the next release" should replace "Product First" as the PTC slogan.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
As an historical note, prior to V10 of UG, you did put the dimensioning in the views and then put the views on the drawings.
Ben Loosli
Ingersoll-Rand
Vince
