Bolting Question
Bolting Question
I am desinging a connection to transfer moment (small amount) and have specified Turn of Nut pretension. Should I design the bolts using SC shear values, or bearing type? There is not tension on the bolt group, long slotted holes are used in the direction of force.
RE: Bolting Question
Ron's comment about tension would be true if ned's connection were an end plate type connection, but from the description given, I don' think that is the case. Rather, I think there are angles, tees or plates connecting the beam flange to the column flange. Ned, am I correct?
chichuck
