Centerlines Not Working
SWX 2005 SP2
I am working on a few different 2d assy drws and I am having a problem with just one of them. On the other drawings, I previously was able to click on the Centerline icon, select an existing view, and then have all of the centerlines appear. It doesn't seem to be working. Any suggestions?
RE: Centerlines Not Working
Have you tested this file on another system?
Have you tried other files on your system?
This will help out file specific or station.
Try these:
FAQ559-908
FAQ559-507
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP2.0 / PDMWorks 05
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
Chris
ctopher's home site
FAQ371-376
FAQ559-1100
FAQ559-1091
FAQ559-716
If not, then try those FAQ's first... I believe the problem is on your system and not SW.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I haven't tried the FAQ's you posted because I didn't think it could be a system thing. Why would the centerlines work on every other drawing file except for this one and why would the same problem be happening on different computers and only with that same file? Some of the other files are alot more complicated and they all contain the same type of parts. I ended up copying another one of my assemblies, erasing all the existing views and then remaking all of the views from the file that didn't work. Centerlines work fine on the new drawing.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
Repair and or modify takes anywhere from 30 seconds to 15 minutes.
Alternative reisntall takes about the same, for someone new to the registry takes about 30 minutes.
Do try them and contact your VAR if you are at a Deadline.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
