Inserting a "Scale" Callout
I have a draft document consisting of two Worksheets: one with drawing views set at 1:2 scale and a second with drawing views set at 1:4 scale. I wish to place a callout in the Title Block at will display the correct scale automatically when I populate the drawing with the part. How do I get SE to pull the scale from each worksheet and place it into the callout on the Title Block?
When I place the callout and chose "Scale" from the "From Current Draft File" selection, I get "NAME?:SCALE" instead of the scale. "From Current Draft File" is the only secltion under the Callout Command that lists "SCALE". When you right click the drawing view to get the view properties, the scale is diplayed but I cannot get this value into the callout.
RE: Inserting a "Scale" Callout
--Scott
For some pleasure reading, try FAQ731-376
Currently, only view scales can be listed and it is shown next to the view. You could show one view scale and move it to the title block location. But, if the scale of that view changes and no others do, then the callout will not be entirely accurate.
--Scott
Ken
