Options for 2-hour firewall, spray-on insulation?
I need advise regarding installation of a 2-hour (level 2) firewall to be installed on the unobstructed "Interior" of an Exterior wall 18-feet hight by 150-feet long inside a Metal building on concrete slab built in 1998.
The interior wall is: Exposed veritcal steel beams on 25-foot spacing, and between the beams are vertically-attached plastic-encased insulation. Underneith the insulation are horizonal steel purlins(?) which is what the exterior steel panels are secured to via metal screws.
By the way, the building/warehouse is currently occupied :-(
Several ideas have been proposed... one is Multiple layers of sheetrock attached to new steel studding frame. Another was Masonry blocks, but steel rebar would need to be installed inside them for strength from floor to celing.
I have been reading that there is a 2-hour rated "spray on" Insualtion or else applied via the tradational fill or attach method.
Anyone have any suggestions?
Thank you, Brett Slack wd4dx@hotmail.com
RE: Options for 2-hour firewall, spray-on insulation?
I also wonder what a simple "google" search may turn up?
-Brett
