CASINO AIR CHANGE RATE
Dear friends:
Do you know about any code or standard that recommends or indicates a minimal madatory air conditioned air changes for casinos and bingos?
RE: CASINO AIR CHANGE RATE
HVAC68
a. Fresh air rate.
b. Total air conditioned supply rate.
a. will depend on the use of the space and if smoking is allowed. Generally 8l/sec per person freash air if no smoking and 16l/sec per person with smoking.(in pubs this can be up to 15ac/hr for busy high population density spaces)
b. As walkes says,work out the space heating and ccooling load and the airflow needed to heat and cool the room. This usually exceeds the fresh air rate.Typically this can be 10 to 30ac/hr. At rates above 20ac/hr you need to be careful how you put the air in as it can get draughty. (Try Swirl diffusers or displacement vent if the space is high enough)
Friar Tuck of Sherwood
The practise has certain implications to other design details as well. That atmosphere makes certain surface finishes decay or discolor comparatively quickly, and can create some very biologically active "hot points" such as fountains.
In the past there were even accusations that central nervous system depressants were being introduced to the airstream...Rest of the story holds that when the objections surfaced, the response was to quit another practise. Diluting the liquor....
