colorize assembly macro, need assistance.
I've got a macro that colorizes an assembly. I can get it to colorize it the first time but it should keep randomly appling colors, as long as you keep running the macro.
'Dim swApp As Object
'Set swApp = Application.SldWorks
Public CompNames As New Collection
Public CompColors As New Collection
Public ComponentName As String
Public R As Double
Public G As Double
Public B As Double
Sub main()
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Dim swAssy As SldWorks.AssemblyDoc
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim nStart As Single
Dim bRet As Boolean
Set swApp = GetObject(, "SldWorks.Application")
Set swModel = swApp.ActiveDoc
Set swConf = swModel.GetActiveConfiguration
Set swRootComp = swConf.GetRootComponent
R = 145
G = 241
B = 135
TraverseComponent swRootComp, 1
swModel.EditRebuild3
MsgBox ("Process Complete")
End Sub
Sub ColorComp(swComp As Component2, swFeat As feature, RVAL As Double, GVAL As Double, Bval As Double)
Dim BoolRes As Boolean
Dim swCompModel As ModelDoc2
If swFeat.Name <> "" Then
MaterialProp = swFeat.GetMaterialPropertyValues
If IsEmpty(MaterialProp) = False Then
MaterialProp(0) = RVAL / 255
MaterialProp(1) = GVAL / 255
MaterialProp(2) = Bval / 255
BoolRes = swFeat.SetMaterialPropertyValues(MaterialProp)
Else
Set swCompModel = swComp.GetModelDoc
MaterialProp = swCompModel.MaterialPropertyValues
swComp.MaterialPropertyValues = MaterialProp
End If
End If
End Sub
Sub TraverseFeatureFeatures(swComp As Component2, swFeat As SldWorks.feature, nLevel As Long)
Dim swSubFeat As SldWorks.feature
Dim swSubSubFeat As SldWorks.feature
Dim swSubSubSubFeat As SldWorks.feature
Dim I As Integer
Dim Colors
Dim ColorFound As Boolean
ColorFound = False
While Not swFeat Is Nothing
If swFeat.GetTypeName = "DetailCabinet" Then
For I = 1 To CompColors.Count
Colors = Split(CompColors.Item(I), "/")
If Colors(0) = ComponentName Then
R = Colors(1)
G = Colors(2)
B = Colors(3)
ColorFound = True
Exit For
End If
Next
If ColorFound = False Then
CompColors.Add ComponentName & "/" & R & "/" & G & "/" & B
End If
'sbr.Panels(1).Text = ComponentName
ColorComp swComp, swFeat, R, G, B
End If
Set swFeat = swFeat.GetNextFeature
Wend
R = R + 100
G = G - 50
B = B + 120
End Sub
Sub TraverseComponentFeatures(swComp As SldWorks.Component2, nLevel As Long)
Dim swFeat As SldWorks.feature
Set swFeat = swComp.FirstFeature
' MsgBox swFeat.Name & " - " & swFeat.GetTypeName
TraverseFeatureFeatures swComp, swFeat, nLevel
End Sub
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim swCompConfig As SldWorks.Configuration
Dim sPadStr As String
Dim I As Long
Dim J As Integer
Dim SwChildCompDoc As ModelDoc2
Dim NameFound As Boolean
NameFound = False
vChildComp = swComp.GetChildren
For I = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(I)
Set SwChildCompDoc = swChildComp.GetModelDoc
If Not SwChildCompDoc Is Nothing Then 'I added this line to prevent an error - D Schuman
If SwChildCompDoc.GetType = swDocPART Then
For J = 1 To CompNames.Count
If CompNames.Item(J) = swChildComp.Name2 Then
NameFound = True
End If
Next
If NameFound = False Then
CompNames.Add swChildComp.Name2
ComponentName = SwChildCompDoc.GetTitle
' MsgBox (ComponentName)
TraverseComponentFeatures swChildComp, nLevel
End If
End If
TraverseComponent swChildComp, nLevel + 1
End If
Next I
End Sub
Public R As Double
Public G As Double
Public B As Double
Sub main()
Dim bRet As Boolean
R = 145
G = 241
B = 135
End Sub
Else
End If
End If
End Sub
Dim I As Integer
Dim Colors
ColorFound = False
R = Colors(1)
G = Colors(2)
B = Colors(3)
ColorFound = True
Exit For
End If
Next
End If
End If
Wend
R = R + 100
G = G - 50
B = B + 120
End Sub
End Sub
Dim I As Long
Dim J As Integer
NameFound = False
NameFound = True
End If
Next
End If
End If
End If
Next I
End Sub
