Green House Gas Problem
Okay, I have an engineering problem that needs solved.
We are giving off lots of CO2 emmisions.
I need to find a cost effective way to seperate the O2 to be bottled for pharmacutical uses.
I also need to find a way to take the C left, and form it into diamonds for sale.
Any suggestions on taking care of the green house gas problem?
RE: Green House Gas Problem
Why not bubble it through water and sell acid?
There's are these bio-machines called "vegetation" and "algae" that convert CO2 into O2 and accumlates the C in biotissue which can then be harvested.  I don't know about the diamond part.  Taking care of the green house gas problem could be faciliated by using these bio-machines throughout our engineered environments instead of replacing this infrastructure with less/non- effective systems such as paved surfaces.
Look out a window over any City in the US and you will see what I mean, there is vast wasted space on rooftops that can be vegetated, for instance.  This is happening in Berlin and Sweden, and now Chicago, where developers are required to provide a minimum amount of vegetation on their site.  It's a start!
This doesn't sequester the CO2 - it will come back out of solution. BLT has the more elegant solution.
Rather than compress all the way to diamond, you could compress it into a form similar to anthracite and sell it to blacksmiths. Then again, they will turn it back into CO2...
      "Come to think of it, there are already a million monkeys typing on a million typewriters, and the Usenet is NOTHING like Shakespeare.
       - Blair Houghton
