Cohesion used in stability analysis
I'm trying to validate the use of an allowable unit shearing strength (C) of 0.125 of the compressive strength of a particular concrete. This is about 300 psi for the concrete being used. This C value is being used to do a stability analysis for a dam. Does anyone know about any references that might be able to help me validate this cohesion value?
RE: Cohesion used in stability analysis
They publish guidelines on all types of dam construction.
Try this link: http
otherwise you can go directly to the corps of engineers website.
good luck.
