Running Workbench on PC, solving on UNIX
Does anyone know if it's possible to locally install Workbench on my PC and once pre-processing is done, send the info. to a remote Sun workstation to solve?
I've heard that this is possible so the better questuion might be, how do the two operating systems "talk" to each other?
RE: Running Workbench on PC, solving on UNIX
It's definitely possible (as long as you're running a recent version of workbench), you just need a special licence to do it - ANSYS Professional or aboveI think. Talk to your ANSYS distributor about the "asynchronous solution capability", and they will provide a solution for you. (The two "talk" to each other by a simple NFS and/or Samba-type Unix-Window interface I believe.)
Cheers,
-- drej --
