making parts into configurations.
The project I am working on has required me to make coolant lines from flex tubes, each being a custom configuration. I made each of these tubes (about 300) from within the assembly. Currently each tube in the assembly is assigned a different part name based on the location of the line; however, each one is made from the same tubing material and carries the same mil no. I was wondering if there was a way to take all of these individual parts, and turn them into configurations referencing one single part number.
Each one is basically the same thing... a 3D sketch, and 2 swept concentric circles.
Thanks.
RE: making parts into configurations.
Look at using a DT to control the dimensions. You can't take multipl parts and place them into a single file and turn them into Configurations. You will have to make one part with a Design Table (DT) and plug in the information within the DT and when you close the DT the model will update and list your Configurations.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
