Solidworks Tree Exploding
Is there a way to prevent the solidworks tree from exploding, especially when working in assemblies? It seems to be random but often after applying mates to two different parts in a assembly, one of the other sub-assemblies will have its "listing" expand in the tree. You then have to go and reduce these listings to keep your tree from being overly long. Sorry if I am using the wrong terms here.
Thanks for the help.
RE: Solidworks Tree Exploding
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
"No Jesus, no peace. Know Jesus, know peace!"
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I have just submitted the ER.
The benifit of contacting you VAR is that they can submit the ER under their numbers as well. It helps to have the ERs use the same wording.
Although, I'm not sure how much SWx could do about this particular issue. I have heard that the feature tree uses Windows explorer technology as it's backbone, so the blame could be shifted to MicroSoft.
Tools-Options-FeatureManager
De-select Scroll selected items into view
This does not get to the core issue. Yes the selected items will stop scrolling into view, but the tree will still continue to expend with each assembly mate and rebuild as before. The original question posed in this thread was, "Is there a way to prevent the SolidWorks tree from exploding, especially when working in assemblies?" Your solution will not do away with this problem. Not to be proud or boastful, but only to inform. Hope this helps.
He is the living water. Whoever drinks of this well will never thirst again!
