Help with clock synchronization
Hi.. i am new to this forum, and i dont know if this is the right place to put this question. I am doing an A/D (analog to digital converter)-D/A scheme, in which i have to transfer voice across a fiber optic wire.
My bit clock is 256Mhz, and sampling clock is 8Mhz,and the system clock is 2Mhz. I need to synchronize clocks at my reciever (D/A) with the clocks at the A/D.The problem is, my A/D internally compresses a 13 bit resolution to 8 bits, so i dont know if i can use a clock recovery circuit at the reciver. It encodes the signal by what's called the "A-law" encoding scheme, but the signal does return to zero.
I'd appreciate any suggestions.. i am not sure how i can synchronzie clocks either.
