Inserting Leaders
Inserting Leaders
Inserting Leaders
I am new to Solid Edge and I have a leader with a note and I want to point to 10 objects.  I have no problem with the arrow side snapping to the object, but the non arrow side looks messy.  Is there a way to get the non arrow side to all snap to the same point?
I am using Solid Edge version 16.
RE: Inserting Leaders
Draw a point with the "Point" command in the Drawing Toolbar, then click it for the second point the leader.
- SESM
Using the leader command, it will attach to the break line vertex of the original callout.  If it needs to "wrap" around geometry, additional segments can be created by adding vertexes by selecting the leader and then holding down the alt key and clicking on the line at the point where a vertex is desired.  Then just drag the handles.
Ken
