compression test on sand
A chemical has been developed for dust abatement, made up of polysaccharide, surfactant, mordant and water.
I have to perform a compression test on the sample (solution mixed with sand and cured). The resulting crust is similar to concrete, but not as strong. I have to test various concentrations of the solution and correlate compressive strength of the crust with concentration.
MY QUESTION: Does anyone have guidelines for the sample preparation (size, shape...) and testing?
We are using an Instron 5500R, which uses 2 disks for compression.
RE: compression test on sand
ASTM International has several standards for compression testing of various materials.  For example:
C39/C39M-04a Standard Test Method for Compressive Strength of Cylindrical Concrete Specimens
You can search for these at:
http://www.astm.org
Cory
Thanks for the reply, Cory.
I should have mentioned in my message that I have a couple of ASTM standards: for cohesive soil and for concrete.
The resulting crust lies somewhere in between. I was hoping someone would have experience with something comparable, and would have some insights to share.
Thanks again,
Marc
Perform a search at the ASTM Internet site - there are hundreds of standards in this general area, and you should be able to find a suitable one.
Cory
