PRESSURE TEST ON BOILERS
Hey there, Just on equestion, When performing pressure test on a water tube steam boiler, is there any recomendation about the rate pressure should be increased until reached the test pressure I mean how many Psi we must increase per minute untiel we reach the pressure requeired?
best regards!
RE: PRESSURE TEST ON BOILERS
No, none that I am aware of.
falco,
Agree with metengr that there is not minimum rate required for pressure increase per minute for a boiler test.  If the pressure does not seem to increase quickly, while pumping into boiler at a good flow, then there could probably be air that has not been vented from the boiler.  Maximum pressure increase rates would follow from safe practices.  Pressure increase by stages, 25%-50%, would allow time for catching gross leaks.  Putting full BFW pressure suddenly on filled boiler might pop pressure relief valves.
Break the pressure increase into stages say 25% 50% 75% 90% 100% - and hold for a short time at preceding stages to check for pressure drop.
Cheers
Rob
