Low Cost Pressure Transducer
I'm looking for a pressure transducer that will measure pressures in the range 0-4000psi and can stand spikes to 6000psi. This is a low-cost high-volume automotive application (production volume in the range 5000 units per year).
I'm making an appeal to the great wisdom of this board, and asking if anybody has an idea which vendor might entertain such a specific application? All the sensors I'm seeing are in the $100+ price range, which is too high.
Thanks!
-Damon
Thanks!
-Damon
RE: Low Cost Pressure Transducer
Bud Trinkel CFPE
HYDRA-PNEU CONSULTING, INC.
fluidpower1 @ hotmail.com
http://www.fluidpower1.us
-Damon
http://www.entran.com/plowhi.htm
Bud Trinkel CFPE
-Damon
http://www.dynisco.com/
http://www.viatran.com/
John
Most of these sensors have accuracy to .25% FS, I would be happy with 2% or even worse. Seems nobody makes such a thing.
-Damon
Usually the only restriction is that your order in specific size lots.
I am currently looking for a $10 sensor as well though my app is lower pressure. I currently have a quote from TI of $30@5K and am going to be calling GE today. I still have to get the boss to find out the actual pressure the cust is trying to read.
The thing to remember is that 99% of google hits that are actually selling what you are looking for are actually only resellers, not manufacturers. Since these transducers are actually made by semicondutor houses, I have my doubts about GE being usefull.
http://djinstruments.com/model_gg.html
They are saying that that one will be around $20 in aluminum unamplified...more a little more for an amplifier or for steel.
-Damon
68CP series
1KU $30
5KU $19.20
10KU $16.85
15KU $15.25
20KU $13.50
I tried to find the 68CP series on their web site but there was no mention of it. It seems the 6xCP series in their comparison page only goes up to 500psi. What is the pressure range of the 68CP series?
-Damon
They do have a couple of high pressure models, this one is the one they recommended for the lowest cost. The book rate for 5k was $30 but the prices above were actual quotes.
I am guessing the more expensive ones would book for $50. Based on my results you might be able to get them to bid a contract for $35.
DJ Instruments came back with not much better than the $30 for an unamplified sensor at 5K in aircraft grade aluminum. I do not know how far they can go in pressure before needing to switch to stainless but they did say that there was no difference for different pressures as they are custom machined varying the diaphram thickness for the desired pressure. I imagine it is about a $10-20 adder for the amplifier.
-Damon
Dan
