SHORTCUTMENU COMMAND
I AM RUNNING ACAD 2002. I WANT THE RIGHT MOUSE BUTTON TO ACT EXACTLY LIKE IT DID IN R14. IF I TYPE SHORTCUTMENU AT THE COMMAND LINE AND SET THE VARIABLE TO '0', EVERYTHING WORKS EXCEPT WHEN I AM GRIPPING AN OBJECT. I STILL GET THE SHORTCUTMENU INSTEAD OF A REPEAT OF THE LAST COMMAND. IF I CHANGE THE VARIABLE THE OTHER WAY (THROUGH THE OPTIONS TOOL BAR) THE ITEMS DO NOT HOLD. I WILL CHANGE THEM TO WHAT I WANT, DO AN APPLY AND CLOSE, THEN IMMEDIATLEY DO THE OPTIONS COMMAND AGAIN AND THEY ARE BACK TO WHAT THEY WERE BEFORE I CHANGED THEM. ANYONE ELSE HAD THIS PROBLEM?
RE: SHORTCUTMENU COMMAND
"Everybody is ignorant, only on different subjects." — Will Rogers
