My problem is that I want to cut pr
My problem is that I want to cut profiles but with my actual motor I can not do that, so I want to calculate the cutting power to select my new motor, and also a new belt transmission and I need if it is possible your help. I want to cut steel profiles of 6" height. I will like to know technical data about Tyrolit disc
TYROLIT SECUR KDM 170
A2404BF71M
41F-500x6x80
FA 423738/2/1
the machine tool moves the grinding disc towards the profile, from up to down, while the profile remains without moving, and I will like to know the maximum speed, friction coeficient and other characteristic that will let me calculate the cutting power. Thanks a lot
