HUD Blast Wall Mitigation
I have a proposed HUD housing project that is to abut a property that has a 40,000 LPG above ground tank located on it. HUD requires that any building be a minimum of 750' away from the center of the tank and that common outside areas be 1,300' away. If it is impossible to maintain these distances, mitigation methods can be used. One option is a wall that will resist the pressure of the explosion. HUD doesn't have any guidelines as far as the load capacities for the wall in relation to the distance from the tank. Has anyone designed one of these walls before and what loading have you used? Thanks.
RE: HUD Blast Wall Mitigation
As far as computing the blast pressures there are several documents published by the DoD (department of defense) but I am not sure if they are available to the public. They base their blast pressures by equating the weight to equivalent TNT because most research has been developed around TNT. This is all I can tell you in this forum.
It is my advise to you is hire an engineer who is competent in performing these designs and let them do their magic. This will not make you less professional to your clients and it will produce results that are based on experience and good judgment.
Lutfi
www.cdeco.com
If the government does not allow access to the data you need, because Saddam Hussein had nearly invaded the USA, why not design a tapered, concrete blast wall, using "guesstimated" blast forces? If anyone challenges you to provide a more scientific estimate of blast forces, then challenge them to supply to you a source of that info.
Sorry for the sarcasm- I don't mean to offend anyone.
Now, I realize your problem is quite different as far as the amount of fuel involved. But, you are out doors and bascially want the explosive force to go up, not out. So, while the force on the wall is high and may be subject to high temperature fires, it is actually not as bad as might be thought at first.
I have seen a number of seminars lately that purport to teach how to design blast resistant buildings. I also concure with Lutfi, there are government sites; DOD, FEMA and Homeland Security, that have information on them. Have you done a web search? If the information is not available on the web, try calling a government agency directly to see what information is available.
Try Weidlinger Associates or PB; they do work related to blasts.
The reasons why you can't guess should be obvious - Don't engineer things which you don't understand.
Governments do try to keep the necessary information away from the public but it can be obtained by those who have a genuine need for it.
Stiffener - Do get a specialist to do the design. When you are shopping for a specialist, ask them what data they propose to use as the basis of their design.
