Desert Camouflage texture-map image
Image gurus,
Does anyone know a source for a texture map (the kind that can be tiled so that no borders appear) of the "new" desert camouflage for the US army? I will be using it in assemblies in Pro/E Wildfire 2.0. Some time spent Googling not yield any good results. Thanks in advance.
Best regards,
Matthew Ian Loew
RE: Desert Camouflage texture-map image
Please check on the www.3dcafe.com under the FREE STUFF. There is a special section for textures. See also in the LINK (under TEXTURES):
http://www.3dcafe.com/asp/textures1.asp
If you do not find one, just make one in phoroshop or similar programs.
-Hora
Check here:
http://www.good-tutorials.com/track/2612
-Hora
