Soldering to Ductile Iron
We would like to attach a copper wire to a piece of ductile iron. What is the best method? Is it possible to solder the wire? If so, what solder should be used?
Thank you,
Lee
Thank you,
Lee
RE: Soldering to Ductile Iron
http
Prior to this there were several Cd base solders that worked very well on CI/DI.
