very simple question
hi everybody
what is the difference between switchgear and switchyard?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: very simple question
SWITCHYARD: This term is commonly used by the power plant people and is synonym of high voltage substation witch is the term commonly used in the power utility environment. The system typically begins with the high-voltage terminals of the step-up power transformers and extends to the point where transmission lines are attached to the take-off structures.
