VB scripting - how to address a Product?
I am trying to get a script to run within the context of an assembly, I can't seem to get the "Product related" lines correct.  Any Ideas?
My Script does work when only running in a Catpart...
***********  I'm adding this part (doesn't work)
'find product information
    Dim product1 As product
        Set product1 = CATIA.Activeproduct
        Set product1 = partdocument
*********** For here down works (in a .CatPart)
'set current catia document as current
    Dim partDocument1 As partDocument
        Set partDocument1 = CATIA.ActiveDocument
    Dim ActivePart As Part
        Set ActivePart = partDocument.Part
    Dim parameters1 As parameters
        Set parameters1 = ActivePart.parameters
......etc.....
Any Ideas?
- BsurfN99
RE: VB scripting - how to address a Product?
You could try something like the following:
' Initialise Part Settings
    Dim CurrentDoc As Document
    Set CurrentDoc = CATIA.ActiveDocument
    Dim CurrentProd As Product
    Set CurrentProd = CurrentDoc.Product
It works ok on the macro I'm working on, which follows a similar strategy to the one you describe
If Beethoven had been killed in a plane crash at the age of 22, it would have changed the history of music...
and of aviation.
Thanks, I haven't been able to really see if it works in the context of my assembly though, because I can't seem to get my parameters to connect.  I get an "Run-time error '438': Object doesn't support this property or method"  This error occurs at the *** line.
'find product and part information
     Dim CurrentDoc As document
     Dim CurrentProd As product
     Set CurrentProd = CurrentDoc.product
     Set parameters1 = CurrentDoc.parameters  ***
I'm sure I'm missing something basic here, any ideas?
BsurfN99
I think it should work if you try CurrentProd.parameters instead of CurrentDoc.parameters
and of aviation.
Modifing it to CurrentDoc.parameters, does make it work, except it add the parameters to the product, and not my active part, I would like to be able to add my parameters to my active "catpart" even when in designing within a product.
Thanks for your help...
-BsurfN99
If You want to collect the parameters of the active CATPart in designing product. What you should do is
Dim productDocument1 As ProductDocument
Set productDocument1 = CATIA.ActiveDocument
Dim Rootprod As Product
Set Rootprod = productDocument1.Product
Dim MyProd As product
Set MyProd = Rootprod.products.Item("iproduct.name")
Dim Parameters1 As Parameters
Set Parameters1 = MyProd.Parameters
i = 0
do
    i = i + 1
       Msgbox Parameters1.item(i).Name
loop until i = Prameters1.Count
Hope this would work for you
Thanks for the Ideas, unfortunately that's not what I was tring to do.  It did give me an idea though, I just tried it, it didn't work....
Here is what I am tring do accomplish.
Within any CatPart, wheather I have open just a CatPart or if I am active in a Catpart, within a product; I have set parameters that I may want to apply to my CatPart.
At the moment, I have this working only for working only in a Catpart, It errors out if I try to run it when working in a Catpart that is also in a CatProduct.  I would like to fix this.  I am fairly new to VBA, any help is much appreciated.
Thanks for everyones help...
-BsurfN99
      "The secret to success is the consistency to pursue."
          - Harry F. Banks
The challenge here is that VB calls both CATParts and CATProduct Products.  You need to determine wether or not the part you are working with is actually a CATPart or not. One way of finding this out is to look at the ActPart.Products.Count.  If it is greater than 0, then you are definitely looking at a CATProduct, but if it is 0, you either have a CATPart, or you have a CATProduct with no children.  From there, you can look at the associated Document, to see if it's a CATPart or not.  You could also check to see if the Active Part has a HybridBodies collection, or a Bodies collection.
