bearing loss
bearing loss
Hi, can anyone give me an idea of how significant are bearing rolling losses in a gear train (or more generally, a hard rolling body on a hard flat surface).
Thanks.
Thanks.
RE: bearing loss
M = Mu * P * (d/2)
where
M = friction moment
P = radial load
d = bearing bore diameter
Mu = friction coefficient = 1.0-1.5E-3 for deep groove ball bearings and cylindrical roller bearings, 1.2-1.8E-3 for angle contact ball bearings, 2.0-3.0E-3 for thrust roller bearings etc.
You can compute your fricttion loss power from frictional moment using first principles
Power = 2*Pi*M * rotational frequency
F.A.G. "Rolling Bearing Lubrication" is available for free at www.fag.com ( you have to register). It has a much more detailed formula with a load-dependent portion and a load-independent portion, depending on viscosity and other factors.
