saw cut expansion joints
I am looking for details on exspasion joints in concrete highway construction mainly the silcone sealents and Compression seals how they are applied and manufacturers
RE: saw cut expansion joints
As for sealants, most pavement joints are either polymer modified asphaltic or urethane. Silicone is usually not used for pavement joints.
Pre-formed EPDM or other synthetic "rubber" joint seals are used as well.
Please note that there is little need for "expansion joints" but plenty of need for control and isolation joints, all of which should be sealed against water intrusion.
